Fluent Start Error
Old   July 1, 2007, 10:41
Default Fluent Start Error
Safa
I installed Fluent 6.3.21 on my PC. ( I will use it on Windows XP)
The problem is that when I start it I get this error message:
FLEXlm error: -96,7. System Error: 11004 "WinSock: Valid name, but no record (NO_ADDRESS)"
I have no idea how to solve that especially that I have case and data files that I want to open and dispaly! If there is any possibility to open them using an other program!
Thank you so much in advance!!!
/Safa
Old   July 1, 2007, 14:52
Default Re: Fluent Start Error
taran
Hi I think you should try to create a folder named flexlm in your c drive ( or the drive where you have installed fluent ) and check out if it works
Old   July 1, 2007, 17:43
Safa
Hello, thank you for answering me soon! I just created the folder named FLEXlm, still I get the same error message!!!!!!!!!!!!! What shall I do?
Thanks
/safa
Old   July 2, 2007, 08:48
taran
check out the drive in which you have installed the fluent (make the flexlm folder in that drive ) Also check the fluent license file (sometimes you gotta change the computer' year to the license year )
Old   July 2, 2007, 11:35
taran
POSDAT problem piotka STAR-CD 4 June 12, 2009 08:43
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
