February 19, 2010, 08:54 |
nmake issue with Windows
Sebastian Gatzka
Rep Power: 20 |
Hello World.
Sorry to bother you with this known problem. I know it was discussed before, but in any case I could not find a solution suitable for me. So as the topic reveals the 'nmake' can't be found on my Windows System. I made a full installtion of Visual Studio 2010 RC - not out of fun, but because I work with this version and don't want to get back to Version 2008. I hope version 10 of the Visual Studio may also be able to solve this problem. I'm sure this information is crucial: I'm using a 64bit Windows 7 operating system. Any ideas? Sebastian
Schrödingers wife: "What did you do to the cat? It's half dead!" |
February 20, 2010, 01:34 |
USMAN
Rep Power: 16 |
hi sega,,
The solution of this problem is very simple.If you have installed visual studio and FLuent at default location,add the following lines in the "path" of environmental variables. C:\Program Files\visual studio(ur version)....\common\tools;C:\Program Files\visual studio\common\tools\WinNT;C:\Program Files\visual studio\common\MSDEV98\Bin;C:\Program Files\visual studio\VC98\Bin;C:\Fluent.inc\ntbin\ntx86 The best way to add this into the path of environmental variables is to go into that location and copy the adress and paste it in environmental variable panel. And then open the command prompt window and launch the Fluent from your working directory.There would't be any more problem of "nmeke". Regards |
February 20, 2010, 04:04 |
Sebastian Gatzka
Rep Power: 20 |
Thank you for your quick reply.
But where do I set these environmental pathes? And what is the "command prompt window"? I have read something about this in context with Visual Studio. Or does it it mean the Windows command line?
February 21, 2010, 17:50 |
#4 | |
Sebastian Gatzka
Rep Power: 20 |
I haven't done anything with FLUENT. The problem still exists.
February 21, 2010, 22:50 |
USMAN
Rep Power: 16 |
well sega,,
Right click on my computer > properties > advanced > on the bottom of this panel ,you will find "environmental variables". Many variables would be there in this panel.Find out "path". Click "edit" and add the lines which i have mentioned above. If you don't find the "path" in variable list, click "new" and add this variable yourself. The easy way to edit the path would be to go into that location and copy the adress and then paste it into "path" panel. For eaxample,the first line is C:\program files\visual studio\common\tools Go to your c drive,then program file ,visual studio and then click common and then tools.Now copy this adress and paste it into environmental variable path and so on. For command prompt,go to "All programs" > run. Write " cmd " and press enter. Command window will open.Go to your working directory through this window and launch Fluent. Hope I have made myself clear. Regards |
February 22, 2010, 03:21 |
Sebastian Gatzka
Rep Power: 20 |
Yes, you did make yourself clear. Thank you.
Appartently it worked. There are no more problems with nmake. The building of the UDF runs smoothly. Now a different problem surfaces: My system can't find the open_udf_library! Is this a related problem, or should I consider moving this to a separate thread?
February 22, 2010, 08:58 |
USMAN
Rep Power: 16 |
hi sega,,
After "building" up the library successfully,the system should "load" the library also,,untill there is some compilation error in your udf. If you write the details of the error you are receiving,then i will be able to say something about it. Regards |
February 23, 2010, 09:09 |
Sebastian Gatzka
Rep Power: 20 |
Ok. After clicking "Build" if get this output
Deleted old libudf\win64\3ddp\libudf.dll 1 Datei(en) kopiert. (system "copy "C:\PROGRA~1\ANSYSI~1\v120\fluent"\fluent12.0.16\src\makefile_nt.udf libudf\win64\3ddp\makefile") 1 Datei(en) kopiert. (chdir "libudf")() (chdir "win64\3ddp")() # Generating ud_io1.h myNewUdf.c c:\program files\ansys inc\v120\fluent\fluent12.0.16\src\config.h(110) : error C2143: syntax error : missing '{' before ':' c:\program files\ansys inc\v120\fluent\fluent12.0.16\src\config.h(110) : error C2059: syntax error : ':' C:\PROGRA~1\ANSYSI~1\v120\fluent\fluent12.0.16\cortex\src\dll.h(64) : error C2061: syntax error : identifier 'CX_DLL_GetProc' C:\PROGRA~1\ANSYSI~1\v120\fluent\fluent12.0.16\cortex\src\dll.h(64) : error C2059: syntax error : ';' C:\PROGRA~1\ANSYSI~1\v120\fluent\fluent12.0.16\cortex\src\dll.h(64) : error C2059: syntax error : 'type' Done. Code:
Opening library "libudf"... Error: open_udf_library: Das System kann die angegebene Datei nicht finden. Error: open_udf_library: Das System kann die angegebene Datei nicht finden. Error Object: #f Interrupting... Done.
February 23, 2010, 14:06 |
#9 |
USMAN
Rep Power: 16 |
well,
The library can't be "loaded" untill it is "compiled" properly.It is happening in your case.But the strange thing is nothing wrong in your "udf".The inbuilt header files of Fluent has some error in (110 th) line so it is unable to compile your udf successfully. There can be three possible solution of this problem. 1. Go to program files> Fluent.inc > src. You will find many header files with " .h" name.Find out "config.h" and "dll.h". There is some syntax error in 110 th line of "config.h" and 64th line of "dll.h". Correct these errors according to the "syntax error message"(it means there is some error of sign) which you are getting in Fluent. Unfortunately I can't see the complete error message which you have posted.So I can't tell you the kind of error. If you become successful in correcting these small errors of signs,compile your library again.But always delete the previous library before compiling the library again. 2. Installing the Fluent again may resolve your problem. 3. The versions of "visual studio" and "Fluent" are not compatible if both the previous solutions fail. I wish you all the best !! |
February 23, 2010, 14:29 |
#10 | ||
Sebastian Gatzka
Rep Power: 20 |
config.h(110):error C2143: syntax error : missing '{' before ':' config.h(110):error C2059: syntax error : ':' dll.h(64):error C2061: syntax error : identifier 'CX_DLL_GetProc' dll.h(64):error C2059: syntax error : ';' dll.h(64):error C2059: syntax error : 'type' Quote:
109 #if !(RP_2D || RP_3D) 110 Error: both RP_2D and RP_3D are undefined 109 #endif Code:
FLUENT_EXPORT CX_DLL_PTF_void CX_DLL_GetProc(void *lib, char *name); Thanks a lot so far!
February 24, 2010, 03:32 |
#11 |
USMAN
Rep Power: 16 |
hi sega,,
You are welcome.No need to say thanks.Infact being a student,its a source of learning for me also. As far as I have understood this problem,nothing is wrong in Header files of Fluent.Actually it is a combatibility issue of Windows 7.Either you get a compatible version of "Visual Studio" or change your windows.I know its hard to compromise on the interesting features of Windows 7,,but for CFD point of view,if you go for XP ,your many problems would be solved like "nmake" and opening the library.Windows 7 is new in market and it would take some time to resolve all its bugs. So a very simple solution of all these problems is to change the operating system.If I got any solution to this problem on Windows 7,I will let you know. Regards !! |
February 25, 2010, 07:06 |
#12 |
Sebastian Gatzka
Rep Power: 20 |
I hope you are kidding me. Changing the operation system?
This can't be an option for such an advanced software like FLUENT. So, if you find any hint on how to make this work on Windows 7, please let me know. Meanwhile I will go back to version Visual C++ 2008 and give you a feedback.
March 18, 2010, 12:59 |
#13 |
Sebastian Gatzka
Rep Power: 20 |
Ok. I had to include the Visual Studio and FLUENT path into Windows PATH variables. Now everything works fine.
May 6, 2010, 05:08 |
#14 | |
sigrid
Rep Power: 15 |
I'm also trying to install Fluent 12.1 on windows7, 64bit. If I open fluent through VS cmd I get the same errors as you when I try to load the libary: config.h, dll.h etc... If I open fluent from the startmenu, I get another error: Cannot open include file: stdio.h How did you solve your problem? I have tried to include the enviroment variables mentioned above, but still it doesn't work. Which enviroment variables need to be set? I use VS 2005...should I install 2008 instead? |
May 6, 2010, 06:52 |
#15 |
sigrid
Rep Power: 15 |
hey again...
I added a enviroment variable called INCLUDE and put the link to all includefiles in this one. Now I don't get the error of: cannot find stdio.h, when I open fluent from the startmenu. The error message is now the same as when I open with cmd for VS, namely the one concerning: config.h dll.h etc... Please help me... |
May 6, 2010, 15:29 |
#16 |
Sebastian Gatzka
Rep Power: 20 |
I made a contribution to the Wiki some time ago: http://www.cfd-online.com/Wiki/Fluen...ows_7_64bit.3F
Try it.
May 7, 2010, 02:44 |
#17 |
sigrid
Rep Power: 15 |
Hey,
I found out what was wrong... When you install Visual studio 2005, the x64 comilers and tools are not installed by default. You have to go to language tools -> visual C++ and choose "X64 Compilers and Tools". Then everything works fine |
June 8, 2010, 12:23 |
#18 | |
Pacheo
Rep Power: 16 |
I have the same problems as yours. Here are the basic information of my platform. Win7 ultimate(x64), visual studio 2010 ultimate, ansys 12.1(x64) I've followed your suggestion from wiki website. But I still met with the difficulties as listed: ---------------------------------------------------------------------- d:\ansys inc\v121\fluent\fluent12.1.2\src\config.h(110) : error C2143: syntax error : missing '{' before ':' d:\ansys inc\v121\fluent\fluent12.1.2\src\config.h(110) : error C2059: syntax error : ':' D:\ANSYSI~1\v121\fluent\fluent12.1.2\cortex\src\dl l.h(68) : error C2061: syntax error : identifier 'CX_DLL_GetProc' D:\ANSYSI~1\v121\fluent\fluent12.1.2\cortex\src\dl l.h(68) : error C2059: syntax error : ';' D:\ANSYSI~1\v121\fluent\fluent12.1.2\cortex\src\dl l.h(68) : error C2059: syntax error : 'type' ----------------------------------------------------------------------- Here are my enviroment parameters: Include D:\Program Files\Microsoft Visual Studio 10.0\VC\include lib D:\Program Files\Microsoft Visual Studio 10.0\VC\lib path D:\Program Files\Microsoft Visual Studio 10.0\VC\bin; D:\Program Files\Microsoft Visual Studio 10.0\Common7\Tools; D:\ANSYS Inc\v121\fluent\ntbin\win64 ------------------------------------------------------------ Could u give me a hand on this udf compile thing? Thank you in advance! |
June 12, 2010, 06:37 |
#19 |
Sebastian Gatzka
Rep Power: 20 |
Did you start FLUENT from the SDK command line?
June 16, 2010, 01:16 |
#20 |
Pacheo
Rep Power: 16 |
yup, but when i start SDK command line, the window showed the information as following in yellow characters:
x64 compilers are not currently installed Please go to add/remove programs to update your installation. but i've already installed the x64 compiler and the sdk 7.1 is the new version for win7 x64. Fortunately, I got the the problem solved. I just copied the udf.h from fluent12.1 to the working directory to replace the old one from fluent6.3 and started a new case file. It worked! Thank you for your kindly reply! |
Fluent - Linux vs Windows | derick | FLUENT | 2 | August 16, 2020 11:23 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 7 | January 19, 2010 15:39 |
Linux to Windows (dual boot system) | Alex | Main CFD Forum | 9 | May 3, 2007 03:36 |
nmake | co2 | FLUENT | 1 | January 21, 2004 11:13 |
