June 28, 2007, 06:40 |
use of C program
Help me
If i have datas for each time, i.e., for 1st hour, x =3, so on, is it possible to use those datas as input to the CFD problem. If so please explain me. |
June 28, 2007, 20:25 |
Re: use of C program
V, please specify your problem more clearly...
June 29, 2007, 06:22 |
Hello Tomasz,
I will calculate for example solar radiation heat flux for different times say from morning 6'o clock to evening 6'o clock, on a horizontal plate using say polynomial equation. Now I want to use these datas as input to a problem. How to use these datas for solving the problem using fluent. |
June 29, 2007, 06:59 |
From your question, I think you want to give the heat flux as the time dependent property. If my understanding the question is correct, then you can use read-transient-table option. It is available in TUI mode. Refer user guide for more details. Hope it will help, JSM |
Display Modes | |
Chemkin Forums? PSR.f program help? | johnjohnmulley | Main CFD Forum | 2 | August 5, 2013 07:53 |
Which opensource and free CAD program? | Xwang | Main CFD Forum | 1 | October 24, 2010 17:29 |
Update boundary conditions calculated by an external program | CedricVH | OpenFOAM | 2 | January 15, 2010 11:55 |
Problem in program | tib | FLUENT | 0 | January 28, 2004 14:13 |
How to write a simple program ?? | kokey | FLUENT | 0 | March 19, 2002 10:21 |
