July 2, 2007, 06:42 |
UDF help
Hi all
I request community members to suggest me which command to use for processing Fluent in Batch mode when I have hooked UDF along with it. I was using:- fluent 3d -g -post < myfile.jou or should the command mention in Fluent manual is preferable fluent 3d -g < myfile.jou I am using C shell Linux. Is it neccesary to print the residual monitors in output file. I have included commands in Journal file to write the residual in transcript file. I have an execute-at_end udf which I could load easily but could not manage to hook it with Fluent. I am using /define/user-defined/function-hooks/execute-at-end "my_function::libudf" "" The error appearing is unknown name "myfunction::libudf" is not recognised. Enter valid function in execute-at-end command prompt. Please someone guide me in this regard. |
Dynamic Mesh UDF | Qureshi | FLUENT | 7 | March 23, 2017 07:37 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 22:14 |
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 21:38 |
UDF...UDF...UDF...UDF | Luc SEMINEL | FLUENT | 0 | November 25, 2002 04:03 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 04:01 |
