January 19, 2005, 03:27 |
CHEMKIN
Can anybody explain what is CHEMKIN file for EDC model in combustion simulation? Lorenzo Italy
January 19, 2005, 04:03 |
Re: CHEMKIN
January 19, 2005, 04:23 |
Re: CHEMKIN
Thanks Mark! But I don't argue how can I create a CHEMKIN file and if I must create it or I can.
Lorenzo |
January 19, 2005, 06:39 |
Re: CHEMKIN
drop me an email .. i have some experince with EDC , using fluent, shall be help. (just wanted to send u some tut)
January 19, 2005, 16:59 |
Re: CHEMKIN
The EDC model incorporates chemical kinetic effects into flames (as opposed to fast or equilibrium chemistry). You hence need a chemical mechanism. Chemkin is the standard format for chemical mechanisms, and Fluent allows you to import a Chemkin mechanism.
Try to run the EDC tutorial. For different chemical mechanisms see http://www.reactiondesign.com/suppor...datalinks.html |
August 16, 2009, 16:38 |
hi
Lorenzo i need Spyro Pyrolysis detailed kinetics model for thermal decompozition of hydrocarbon elaborated by Dante and Ranzi from MILANO POlyTECHNIC INSTITUTE do you know if already is adapted for CHEMKIN or Kintecus Thanks |
September 9, 2010, 08:13 |
help
#7 | |
sajjad
please help me thank you |
October 26, 2010, 11:58 |
Hello guys!
Do you know some Chemkin mechanism, with NOx prediction, which properly works in case of flameless combustion? ARM19 is in Chemkin format or it shall be programmed in UDF? Many thanx |
September 18, 2014, 22:15 |
#9 |
zdx
Rep Power: 11 |
hi,zxaar,I use the EDC model with methanol(it's mechanism includes 21 species,93reactions) and CH4(it's mechanism includes 53 species,over 300 reactions) to simulate an unsteady case,but encoutering some troubles,will you please send me some tutorials about EDC in FLUENT,my emails zhuoerbufan89@126.com .
thanks a lot. |
Chemkin | parisa.sayad | Main CFD Forum | 12 | May 2, 2023 23:17 |
Chemkin Forums? PSR.f program help? | johnjohnmulley | Main CFD Forum | 2 | August 5, 2013 07:53 |
Chemkin Pro and Chemkin CFD | Ekiguy | FLUENT | 0 | July 5, 2010 08:04 |
CFX and Chemkin file | Margherita | CFX | 1 | September 30, 2009 19:33 |
Question on CHEMKIN INTERFACE | Rui Yang | Phoenics | 7 | January 30, 2002 04:04 |
