Use Solution as a Known variable
Old   July 3, 2007, 08:35
Default Use Solution as a Known variable
Hesam
I want to solve Fluid flow in a fine mesh grid and then use its solution in same structure (with different mesh) as a KNOWN Variable. Should I use interpolate? If yes, How I can use calculated output as a known variable without resolving?
Is it possible to export solution to another structure witch has few differences with main structure?
Thanks for your attentioin!
Old   July 4, 2007, 07:22
Default Re: Use Solution as a Known variable
mayur
for same geometry u can use interpolate function of fluent... just use the interpolate option from fluent...
if geometry is different this is not possible.
Neumann Boundary Condition for Poisson Equation solution in Polar Coordinates prapanj Main CFD Forum 2 July 30, 2011 19:07
Additional Variable tav98f CFX 3 April 28, 2011 12:33
emag beta feature: charge density charlotte CFX 4 March 22, 2011 09:14
UDF solution variable for time-averaged mass frac? A. S. FLUENT 0 May 14, 2007 16:44
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
