July 6, 2007, 16:32 |
GAMBIT - warn about geometric tolerance
I have a problem with meshing an airfoil in GAMBIT, I use a very fine mesh of order 1e-06 at the wall for obtaining an y+ = 1. The error :
WARN: Mesh size on face.2 is smaller than the geometric tolerance. For an accurate mesh use larger mesh sizes and/or create geometry at a larger scale. Thanks for your help. |
July 6, 2007, 23:49 |
Re: GAMBIT - warn about geometric tolerance
Could you model the geometry in mm or smaller dimensions or change the tolerance?
July 7, 2007, 09:48 |
I could try using mm ... it should work with a 1e-03 smallest cell height. Thanks.
Errors during exporting from Gambit to Fluent | redrum | FLUENT | 3 | August 6, 2014 22:40 |
[GAMBIT] gambit global geometric tolerance | alireza2475 | ANSYS Meshing & Geometry | 1 | July 19, 2010 01:23 |
Gambit 2.3.16, Xming or Exceed...HELP! | bambam3417 | FLUENT | 10 | May 7, 2010 12:39 |
Tolerance in GAMBIT Help!!!!!! | Lottar | FLUENT | 0 | October 6, 2008 14:03 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
