July 9, 2007, 07:07 |
Numerical dispersion?
Hello, i'm modelling water flow between 2 parallel smooth plates. The model is then like a long thin box with a length of 26.8cm a width of 17.7cm and a height of 1.06mm. I'm using a laminar solution and i'm recording the discharge through the outlet gradually increasing the gradient from 0.0005 to 1. I expect the discharge to be linearly related to the gradient. But i found out that increasing the gradient the ratio discharge/gradient is not constant but it sensibly decreases. Do you think in this system non linear pressure losses could arise affecting the linearity, or is it possible that numerical dispersion causes this discrepancy(i tried to refine the mesh but it doesn't affect the results)?
July 9, 2007, 07:09 |
Re: Numerical dispersion?
Sorry i meant numerical diffusion
Numerical viscosity due to the MUSCL and HLL coulpled scheme | sonsiest | Main CFD Forum | 0 | May 23, 2011 15:37 |
Turbulent Dispersion for Coal Combustion | gravis | CFX | 2 | March 23, 2010 23:56 |
Measuring numerical diffusion and dispersion - strange effects | cbeck | OpenFOAM Running, Solving & CFD | 0 | March 31, 2009 16:51 |
HELP: diffusion & dispersion of particle method | QU KUN | Main CFD Forum | 0 | January 22, 2004 01:21 |
New Books and Numerical Software | Eleuterio TORO | Main CFD Forum | 0 | December 18, 1998 12:41 |
