-   -   Multiphase flow (http://www.cfd-online.com/Forums/fluent/45316-multiphase-flow.html)
sri July 9, 2007 22:09
Multiphase flow
Hi
I am running a case in which liquid and air injected simultaneously into the domain thru two inlets.After few iterations it is giving the following error
turbulent viscosity limited to viscosity ratio of 1.000000e+005 in 71644 cells Error: > (greater-than): invalid argument [2]: wrong type [not a number] Error Object: 1.#inf
The same case when I run with single phase(turn off multiphase) is working fine.
What could be the problem in the multiphase flow.
I would appreciate it if you can help me in this regard
Thanks Sri
