how can i list node temperatur by node location
hi i need report include node tempreture by node location, how can i get this in fluent?
Re: how can i list node temperatur by node locatio
create a point surface and monitor/report this surface
"Node values are calculated by fluent by averaging the values of the surrounding cells using a weighting defined by the inverse of the distance between the node and each cell centroid." :) This should help, since cell values are easy to get by UDF and then distances too...
