July 13, 2007, 18:34 |
How to model this case in fluent?
Hi, fluent fans:
I have a problem in solve this case: the tube has solid walls all around - same boundary conditions on all four sides - left side, right side, top side, and bottom side. There is a high pressure region on the left and a low pressure region on the right separated by a diaphram. At t=0, the diaphram is removed and the pressure will create a flow from left to right. Which kind of model can I use to simulate this condition. I can try it as a 1d or 2d problem. Thanks! |
July 16, 2007, 18:53 |
Re: How to model this case in fluent?
this is a shock tube problem. I have tried many method, but still can not the result, did any one can help?
Thanks in advance! |
July 17, 2007, 15:20 |
This problem should possible using unsteady density based solver. you have to patch the initial values of pressure. I havn't tried this myself. If you have already tried this and had any difficulties, please share it with us
July 17, 2007, 20:11 |
I have tried this problem, but still can not get accurate result.
I just make a rectangular, 8.2m Ã- 2m, four sides all defined as walls, and make a line just between the center(x=0) as an interior, then make two zones, left has high pressure at about 3.5atm and density=0.445, the right side has the lower pressure at about 0.5atm and density=0.5. I just use patch after the initialize. In fluent, read the case, then check the grid, it's ok. Define-> models->solver->coupled->unsteady Define->energy Define->viscous ->k-epsilon(2-eqn) Define->material ->ideal gases Define->operation condition ->operation pressure=0 Define->boundary condition(nothing need to define) Solve->controls->solution controls->pressure velocity coupling->piso Solve->monitors->convergence criterion(change all values to 0.000001) Solve->initialization->gauge pressure=3.5atm, temperature=400k Solve-> initialization->patch initialization->set the pressure for the left zone3.5atm, temperature=2789k, set the pressure for the right zone0.5atm, temperature=400k, set all the velocity=0 Solve->iterate, set the time step size=0.0001s, then iterate. But it can not convergence, after about 500 steps, it is said, divided by zero. The problem is the pressure of the left side changed a lot, especially at the x=-4.1m, but the center is changed not so much, and the pressure in the right zone changed a little near the center. This is not as expected, I don't know why? Any advices? Thanks in advance. |
July 17, 2007, 20:13 |
I only have the version of 6.2, so it don't have density based solver.
Display Modes | |
Seeking Macroscopic Particle Model in Fluent | bzhang7 | FLUENT | 3 | June 25, 2022 18:54 |
Reynolds Stress model in CFX vs Fluent | Tim | CFX | 1 | October 7, 2009 07:19 |
self-built model embeded in FLUENT | Jiedong | FLUENT | 0 | January 22, 2009 03:57 |
heat transfer with s2s radiation model in fluent | D. L. | FLUENT | 3 | July 31, 2008 08:40 |
Covert Star-CD model to FLUENT | Lam | Siemens | 6 | June 24, 2003 21:21 |
