July 16, 2007, 05:27 |
Boundary conditions at certain points
I want to calculate the heat transfer in a solid material, a 3D-model that has the shape of a thick bowl. I know the temperature on the outer surface and want to calculate the temperature on the inner surface, from measurements I also know the temperature at a number of points inside the material and the heat flow from the outer wall (this could be considered as an inverse heat transfer problem). I want to use these measured values as boundary conditions, can I apply boundary conditions to certain points?
It is possible to use these points to calculate isotherms, then maybe I could use the isotherms as walls with constant temperature, if that makes the problem easier? |
July 16, 2007, 08:19 |
Re: Boundary conditions at certain points
If you set the (known) temperature on the outer wall and set a reasonable estimate for the heat transfer coefficient for the internal surface you should get reasonable results.
You can then use your internal temperature measurements and outer wall flux for validation purposes. |
Display Modes | |
Impinging Jet Boundary Conditions | Anindya | Main CFD Forum | 25 | February 27, 2016 13:58 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
New topic on same subject - Flow around race car | Tudor Miron | CFX | 15 | April 2, 2004 07:18 |
Please help with flow around car modelling! | Tudor Miron | CFX | 17 | March 19, 2004 20:23 |
Boundary Conditions | Jan Ramboer | Main CFD Forum | 11 | August 16, 1999 09:59 |
