July 13, 2007, 10:56 |
FLUENT Supersonic Combustion
Hello, I am modelling Supersonic Combstion with Fluent.
I started with a 2d case Coupled Implicit solver, and every thing was pretty fine. The CFL number had to remain under 1 though ( slow convergence, anyway). Now I try to do the same with a 3d calculation,it is VERY Slow. I am currently computing a mixing case. What should I do. Is it a problem linked to Couple or Implicit solver? |
July 17, 2007, 01:38 |
Re: FLUENT Supersonic Combustion
yes it is!try changing the courant number(incresing) for every set of time steps after the solution got stabilised.
supersonic combustion in Fluent | argeus | FLUENT | 2 | April 2, 2023 06:39 |
Assistance for modelling unsteady supersonic flow in FLUENT | SATISH A.V | FLUENT | 11 | October 1, 2014 22:36 |
combustion of particle in fluent | Devy | FLUENT | 0 | March 13, 2003 05:12 |
Can I use Fluent to stimulate diesel combustion | Allanhill | FLUENT | 1 | March 6, 2003 07:46 |
which combustion model can be in supersonic field | cfdfans | FLUENT | 0 | March 9, 2001 22:13 |
