-   -   Can mesh adaptation be used with dynamic meshing? (http://www.cfd-online.com/Forums/fluent/45445-can-mesh-adaptation-used-dynamic-meshing.html)
BillH July 19, 2007 15:52
The model compatibility chart in the users guide appendix does not address this combination?
Ideally I want to be able to move a boundary of my model and use dynamic adaptation based on velocity gradients at the same time.
Thanks.
red lemon July 19, 2007 18:06
Re: Can mesh adaptation be used with dynamic meshi
Dont see a reason why you cannot do that. Try it on a simple 2D case first.
red lemon July 22, 2007 16:35
As mentioned above (but for others) you cannot remesh a hanging node/polyhedral/hexcore mesh so adaption and dynamic meshing together will only work if adaption is conformal.
