-   -   Wall Heat Flux Boundaries conditions (http://www.cfd-online.com/Forums/fluent/45475-wall-heat-flux-boundaries-conditions.html)
Abigail July 23, 2007 09:20
I want to include heat flux from some surfaces in the domain. When using Heat flux as a thermal boundary condition on a wall its gives the option of Heat Flux and Heat Generation. Do you need to input values for both?
red lemon July 23, 2007 13:45
Re: Wall Heat Flux Boundaries conditions
No just import one. Then check using report>fluxes to be happy.
Ken Adams July 24, 2007 09:34
This "Heat Generation Rate" is meant for a wall of non-zero thickness (you may find "Wall Thickness" above "Heat Generation Rate") which generates heat like a printed circuit board. If interested, you can read Fluent 6.2 manual 7.13.1 Thin Wall Thermal Resistance Parameters.
Hope it helps,
Ken
