y+ adaption
Old   July 23, 2007, 19:30
Default y+ adaption
AAA
Hey
I'm simulating a negatively buoyant flow near a vertical wall. I'm using the standard wall function which requires a y+ value in the range of 30 to 300. I don't want to go back to Gambit to change the mesh, so I'm using the adaption feature to coarsen the mesh near the wall up to a value in that range. I can refine but not coarsen the mesh (including Adaption with Gradients etc.). Is there a way to coarsen the mesh?
Regards AAA
Old   July 24, 2007, 15:22
Default Re: y+ adaption
red lemon
you cannot coarsen a mesh beyond the original mesh density. You can refine then coarsen but if you want coarser than original you need to remesh. You may be able to use the MDM remeshing tools to do this if you have to stay in Fluent.
Old   July 24, 2007, 19:21
AAA
Thanks for the tip, red lemon. You are the best.
Kind Regards
AAA
Mesh Adaption in CFX. Kushagra Mittal CFX 1 August 31, 2011 08:17
Unstructured Mesh using Mesh adaption sidzishere CFX 1 May 31, 2011 10:18
boundary adaption with geometry based adaption Kate FLUENT 0 October 9, 2005 10:44
Need help with Grid Adaption _stephen_ FLUENT 0 January 13, 2005 07:07
Got unknown element in Post after adaption Atit CFX 0 March 2, 2004 06:42
