gambit meshing
Old   July 24, 2007, 00:16
Default gambit meshing
solomon
hi
i am modelling a heat transfer problem for that i am creating a mesh in gambit which consist of a cavity with(inside) different solid regions.models were created by spliting the solid regions and when i mesh,the entities were not connected.how can i connect?
thank you
Old   July 24, 2007, 03:44
Default Re: gambit meshing
ritmat
mesh>face > connect-disconnect button and selct your faces to be connected. Hope it is what you want
Old   July 24, 2007, 09:08
Ken Adams
When you split your solids, you could select the "Connected" option in the "Split Volume" form.
Hope it helps,
Ken
Old   July 24, 2007, 13:53
red lemon
Check connectivity by displaying by connectivity instead of topology (default) so you can clearly see what is connected and what is not.
Old   July 24, 2007, 23:23
solomon
can u tell me where is this option?
Old   July 25, 2007, 15:05
red lemon
check the buttons at the bottom right
Old   July 25, 2007, 23:53
solomon
ok thank you
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 05:22
[GAMBIT] Desperate student needs help meshing 3D GAMBIT model - please help! lau06165 ANSYS Meshing & Geometry 1 March 22, 2010 01:09
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 20, 2006 23:31
Meshing Aircraft with Gambit Ed FLUENT 5 November 9, 2004 05:04
