mesh import question
Old   July 24, 2007, 17:04
Default mesh import question
brian
I imported a large mesh from gambit. I think it still works and made it in alright but I got this warning:
"thread 60 has 5 contiguous regions"
any ideas what this means?
thanks
Old   August 1, 2007, 01:19
Default Re: mesh import question
oxalis
it means that in a volume, you have a face that separate you volume.
for example: u have a pipe (set as one volume). the pipe is created by two half circular volume. then the common face of this half circular will make fluent confuse. it's like you tell fluent that the pipe (1/2 circular +1/2 circular) is one volume, but you have a common face between this cylinder that makes them looks like two separate volume.
sorry, i don't have a drawing to explain
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
problems import mesh from icem11!!! Julieta CFX 4 March 23, 2008 09:17
import mesh problem Wendy CFX 2 February 6, 2002 05:39
