-   -   Removing lines from partitions (http://www.cfd-online.com/Forums/fluent/45515-removing-lines-partitions.html)
Josh July 26, 2007 03:14
When I produce a shaded plot and I include the grid for showing the outline I also get the lines which shows the partition of the mesh. Is there a way of removing those lines and still shows the outline of the surface. Thanks in advance Josh
Josh July 26, 2007 03:15
Re: Removing lines from partitions
I forgot, I need to postproces in parallel I do not have enough memory on a single computer
AAA July 26, 2007 15:30
Hey
Go to "Specify Display Atributes", second button from the left on the bottom of the page. Next to "Mesh", press Off and then "Apply".
Good luck
AAA
bashu July 26, 2007 16:44
AAA,
I think Josh is talking about Fluent display not Gambit.
Josh July 26, 2007 16:57
That is correct
AAA July 26, 2007 17:41
Hey
What do you mean by shaded plot? Is it xy plot? contours? grid?
Regards
AAA
Josh July 26, 2007 17:43
If a create a contour plot and display the grid as outline edges then I can also see the dividing lines for the partitioning.
barracuda July 27, 2007 10:33
Bump - I'd also like to know the answer to this question!
