Home > Forums > FLUENT
New to Fluent!!!!
Old   July 26, 2007, 17:01
Default New to Fluent!!!!
Hello, I am trying to model the flow of air moving from ambient into a pipe that is connected behind to a vacuum pump. The pump has a fixed pumping capacity of set mass flow rate/velocity. What I am not sure is how to model the inlet BCs. The whole system is atmosphere and the inlet mouth of the pipe is outlet of the domain I am interested in.
Can anyone throw a hint on how I can model this problem at the atmosphere end?
Thank you
Old   July 30, 2007, 16:17
Default Re: New to Fluent!!!!
red lemon
If its moving from ambient use total inlet pressure at inlet of 1 atm. For exit use target mass flow rate then you will see negative gauge pressure at exit if operating pressure is set to 1atm.
Thread Tools
Trackbacks are On
A Problem of Fluent Interpreted UDF: parse error knight Fluent UDF and Scheme Programming 12 March 5, 2016 02:26
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 7 May 22, 2014 22:30
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 4 September 20, 2013 16:30
Compared MRFSimpleFoam and Fluent in a centrifugal pump! renyun0511 OpenFOAM Running, Solving & CFD 8 July 6, 2010 06:24
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 17:48
