Home > Forums > FLUENT
grid checking is field
Old   July 27, 2007, 14:29
Default grid checking is field
sajjad ahmad
i have problem in grid checking of gambit geometry.plz give me some tips so that i identify problem in the grid. fluent do not run the mesh file and show warning like that: Grid check failed Non-positive volumes exist plz inform me quickly
Old   July 27, 2007, 16:18
Default Re: grid checking is field
AAA
Hi
Check the grid in Gambit first. Right-click on the exclamation mark (!) and choose the "check mark" and see the message provided. perform this on each face/volume to find where exactly the problem is.
I get this message when a zone is not properly meshed. Do you have a highly curved line on a meshed face and not enough nodes on it? check the mesh there.
Good luck
AAA
Old   July 30, 2007, 06:30
farhan
I think its related to your computational axis. all the cells should be right handed. check for this. you can fix it in gridgen or gambit whichever mesh generator u r using
Thread Tools
Trackbacks are On
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
HELPInstallation on RedHat90 booosix OpenFOAM Installation 8 July 17, 2007 06:40
Help%7e%7einstall openfoam13 on fc5%7e%7e aderliner OpenFOAM Installation 2 September 11, 2006 07:24
On grid independent solution for pulsatile flow David FLUENT 4 June 8, 2005 16:20
Grid Checking Taskin FLUENT 3 November 15, 2004 04:47
