Memory problem
Old   July 31, 2007, 02:13
Default Memory problem
mourya
Dear all,
I am using 4 GB Ram and Dual processor system, i am running one simulation in that cell count around 20 lacks, while running its giving error and exiting from the run. this is the error message i got.
iter continuity x-velocity y-velocity z-velocity time/iter
Error: 1000000: Failed to allocate 56.25MB memory (..\..\src\amgif.c:1064)
Error Object: ()
Old   August 1, 2007, 01:11
Default Re: Memory problem
oxalis
do you use coupled solver? because coupled consumes more memory (around double the segregated solver)
have u activated both of the processor (you have dual)? because I read in a fluent newsletter, that you must activate both processor first.
Old   August 2, 2007, 07:09
sunil
is there any suitable way to remove this error??...means find out the nodes of grid which will be sufficient according to memory ??
Old   August 2, 2007, 08:04
oxalis
there is unwitten rule that 1 GHz is for 1 million grids (for segregated), around 500.000 for coupled. but this number is just approximation
combustion problem mcnair CFX 9 March 22, 2011 14:06
Fluent Parallel Memory Usage David Christopher FLUENT 1 March 3, 2011 02:20
RAM memory problem alpha Main CFD Forum 8 February 12, 2008 11:07
memory problem Matt FLUENT 1 October 1, 2006 18:24
"Memory too low" problem with Fluent HELP NEEDED Amr FLUENT 6 May 8, 2006 12:06
