July 28, 2007, 00:24 |
urgent need of help! please
Hey,
I was wondering if anyone knows where i can view/downlaod a tutorial dealing with the prediction of aerodynamically generated sound past a circular cylinder or if anyone can guide me in using fluent to predict the sound generated due to flow past a circular cylinder Thanks...please help! |
July 30, 2007, 06:03 |
Re: urgent need of help! please
I have done acoustic analsysis using FLUENT but not confident enough about it. But I do have the literature pertaining your problem. you can find the analytical solution for the problem in Blake Flow induced noise.
Fluent uses Hawikings model to predict the sound U can try this one in 2d and check if it works out. Create a cylinder and flow run the code and see if vortices are generated u have and example in fluent for this one and the after running few iterations select the acoustics module and select the cylindrical surface as the source of generating sound and try to find the sound pressure level at a 1 m distance from the source. you should check that you have enough domain to calculate the spl at the required position. well this is a mere suggestion and think may help u bye ramesh |
July 31, 2007, 05:44 |
http://hmf.enseeiht.fr/travaux/CD010...1/num_simu.htm
look at this site it is interesting and is related to your problem |
Display Modes | |
Urgent - Polyflow - particle tracking visualization -Urgent | shafaatht | ANSYS | 0 | October 13, 2010 04:56 |
Urgent, Urgent, a UDF problem, PLEASE HELP!!! | Max | FLUENT | 1 | September 24, 2010 20:30 |
Urgent...urgent...plss!!! | astronome | FLUENT | 0 | October 16, 2009 07:17 |
tmerge urgent urgent | jessica | FLUENT | 4 | July 15, 2006 13:37 |
very urgent pleasade:Cl and Cd values for airfoil | Liaquat | FLUENT | 2 | April 27, 2006 12:20 |
