Home > Forums > FLUENT
combustion modeling
Old   July 31, 2007, 00:56
Default combustion modeling
palani kumar
hi evrione, i am modeling combustion using laminar finite rate turb-chemistry interaction..the user guide tells me to predict the flow with different species first and then switch on the reactions..patching has to be done while switching on the reactions to give the initial spark.. my flow is predicted and while i switch on the volumetric reactions, patch it with temperature of 3000k in the whole fluid zone and iterate it, it does not even iterate once but gives an error msg like
" Error: > (greater-than): invalid argument [2]: wrong type [not a number]
Error Object: nan "
my geometry is a 2 cm dia cylindrical chamber with a convergent nozzle at the exit..the oxidiser comes from the port side nd the fuel comes from the walls of the cylinder..
any suggestions...???
thanks in advance.. palani.
Old   August 1, 2007, 15:24
Default Re: combustion modeling
cg
Try the stiff chemistry option...
Old   August 2, 2007, 17:55
Default premixed combustion modeling
fethi
Dear; I found difficult to apply the simulation on the premixed combustion case, for example I don't know how to define the mixture (fuel & oxider), Re, Da, Ka and ะค. Can you to send me a tutorial about this case or simply guide me to apply it on my case study.
thank you
Thread Tools
Trackbacks are On
Combustion modeling SuperPahan CFX 6 September 9, 2010 11:57
A role of combustion modeling in flow solver? Yoon Main CFD Forum 0 November 26, 2006 13:00
Modeling question: coal combustion Pablo Sanchez FLUENT 4 August 28, 2006 01:32
Combustion Modeling and Science Forum MonteCarloPDF_PHDstudent Main CFD Forum 0 July 19, 2005 01:53
Combustion Modeling Pravin Naphade FLUENT 0 May 27, 2004 02:51
