Home > Forums > FLUENT
multiphase velocities——VOF
Old   July 31, 2007, 23:30
Default multiphase velocities——VOF
David
hello everybody.
I'm using VOF to modeling my problems,program is list below,the question is: C_U(c,pri_ph),C_U(c,sec_ph)and C_U(c,mix_ph) returns same values, the relative velocity of the primary phase and secondary phase is zero.why?
DEFINE_SOURCE(Flg_x,cell,mix_ph,dS,eqn) { Thread **ph; Thread *pri_ph,*sec_ph; real NV_VEC(ul),NV_VEC(ug),NV_VEC(sub);
ph=THREAD_SUB_THREADS(mix_ph); pri_ph=ph[0]; sec_ph=ph[1]; if(C_VOF(cell,sec_ph)>0 && C_VOF(cell,sec_ph)<1) { ...... NV_D(ul, =, C_U(cell,sec_ph),C_V(cell,sec_ph),0); NV_D(ug, =, C_U(cell,pri_ph),C_V(cell,pri_ph),0); Message("velocity is : %g\n,%g\n,%g\n",ul[0],ug[0]); ...... } }
thanks for your help! David
Thread Tools
Trackbacks are On
Difference of multicomponent and multiphase homogenous flows Luk_Fiz CFX 11 April 4, 2013 05:29
Use data from multiphase into DO radiation yashmash FLUENT 0 October 7, 2011 03:57
multiphase multicomponent physics ckleanth CFX 3 June 4, 2009 20:15
multiphase velocities——VOF David FLUENT 2 August 1, 2007 06:02
Multiphase flow modeling Paul CFX 2 August 11, 2003 09:41
