Home > Forums > FLUENT
multiphase velocities——VOF
Old   August 1, 2007, 00:07
Default multiphase velocities——VOF
David
hello everybody.
I have a question when using VOF,and program is listed below,the C_U(c,pri_ph), C_U(c,sec_ph) and C_U(c,mix_ph) returns same values, so the relative velocity between primary phase and secondary phase is zero.Why?
DEFINE_SOURCE(Flg_x,c,mix_ph,dS,eqn) { Thread **ph; Thread *pri_ph,*sec_ph; real NV_VEC(ul),NV_VEC(ug),NV_VEC(sub);
ph=THREAD_SUB_THREADS(mix_ph); pri_ph=ph[0]; sec_ph=ph[1]; if(C_VOF(c,sec_ph)>0 && C_VOF(c,sec_ph)<1) { ...... NV_D(ul, =, C_U(c,sec_ph),C_V(c,sec_ph),0); NV_D(ug, =, C_U(c,pri_ph),C_V(c,pri_ph),0); NV_VV(sub, =, ul, -,ug); Message("velocity is : %g\n,%g\n",ul[0],ug[0]); ...... } } thanks for your help! David.
Old   August 1, 2007, 04:46
Default Re: multiphase velocities——VOF
Joe
By design VOF uses a common velocity field.
Old   August 1, 2007, 06:02
David
Thank you, Joe. Then how can i get the velocity of primary and secondary phase respectively?
Thread Tools
Trackbacks are On
Difference of multicomponent and multiphase homogenous flows Luk_Fiz CFX 11 April 4, 2013 05:29
Use data from multiphase into DO radiation yashmash FLUENT 0 October 7, 2011 03:57
multiphase multicomponent physics ckleanth CFX 3 June 4, 2009 20:15
multiphase velocities——VOF David FLUENT 0 July 31, 2007 23:30
Multiphase flow modeling Paul CFX 2 August 11, 2003 09:41
