cooling of a hot moving solid
Hi evrybody, Can someone help me ? I want to calculate the cooling of a hot(900K) moving solid in a channel subject to a colder flow (460K). If you want, I could give you precise details on my model.
Thanks for evryone. |
Re: cooling of a hot moving solid
try dynamics mesh and conjugate heat transfer.
Hi!
for uniform velocity and axial direction of moving in a channel without change in cross section area, you can let your solit object stay and move the walls! Ralf |
For the dynamic mesh it's ok but heat transfert don't work.
I tried to create "Interfaces" but the heat isn't transfered to the fluid. I tried to create just walls between the fluide and the solid. Fluent created automatically walls shadow. I don't know which boundary condition I'have to input. Thanks if you can help me |
