August 2, 2007, 03:12 |
cooling of a hot moving solid
Hi evrybody, Can someone help me ? I want to calculate the cooling of a hot(900K) moving solid in a channel subject to a colder flow (460K). If you want, I could give you precise details on my model.
Thanks for evryone. |
August 2, 2007, 11:38 |
Re: cooling of a hot moving solid
try dynamics mesh and conjugate heat transfer.
August 2, 2007, 12:30 |
Hi!
for uniform velocity and axial direction of moving in a channel without change in cross section area, you can let your solit object stay and move the walls! Ralf |
August 3, 2007, 02:38 |
For the dynamic mesh it's ok but heat transfert don't work.
I tried to create "Interfaces" but the heat isn't transfered to the fluid. I tried to create just walls between the fluide and the solid. Fluent created automatically walls shadow. I don't know which boundary condition I'have to input. Thanks if you can help me |
Display Modes | |
Moving Solid! | shashank312 | FLUENT | 3 | May 4, 2021 17:58 |
Moving solid problem | Mudblood | FLUENT | 0 | June 10, 2010 12:11 |
how do I get a solid volume moving? | Katariina | CFX | 2 | March 28, 2008 04:50 |
Cooling conducting solid | Peter | CFX | 0 | January 17, 2002 09:08 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
