August 3, 2007, 05:29 |
Multiple Fluid Zones
I am trying to model a rotating body. I was following Fluent tutorial 8 on Multiple Rotating Frames which uses multiple fluid zones. However there is no corresponding Gambit tutorial which identifies how to do this. I am trying to get my rotor (consisting of 15 blades on a vertical axis) to rotate. However in Gambit it won't allow me to define a fluid zone around the blades I keep getting error messages saying that: Continuum or Boundary conditions specified for faces x and y are not valid for Fluent 6. Can anyone help please? Thanks |
August 3, 2007, 06:27 |
Re: Multiple Fluid Zones
Have you define a zone of fluid in gambit? You must define different zone in Gambit Continuum condition faces. If you do that and it don't work y can't help you.
August 3, 2007, 06:35 |
Olivier, thanks for your reply.
I have 15 blades which have 6 faces each defined as walls. Then I have tried to encompass these is another cylindrical volume which I have defined as a fluid zone in the continuum types. Is this the correct procedure? Thanks again |
August 3, 2007, 07:23 |
I think it is correct. But if it doesn't work I don't know what you can do.
Good luck for your model. |
boundary condition between porous and fluid zones | Mansureh | FLUENT | 5 | June 5, 2011 09:31 |
How to use / How to find IPMT? | camoesas | CFX | 2 | November 23, 2010 06:36 |
Fluid Dynamics Eng - PAX Mixer - San Rafael, CA | Gary Jong | FLUENT | 0 | February 25, 2008 20:46 |
My Revised "Time Vs Energy" Article For Review | Abhi | Main CFD Forum | 2 | July 9, 2002 09:08 |
