August 3, 2007, 10:36 |
Help on VOF boundary conditions
I try to use VOF to model flow through a channel/detention pond with weir as outlet. It's 2 phases:Inlet I air and Inlet II water (air in the top and an initial water depth in the channel before the weir).I am pretty sure about velocity inlet and wall boundary conditions. I wonder what boundary conditions can I apply in the top air portion (pressure outlet?)and weir outlet? I am using Fluent version 6.0. Thanks for your attention. Kelly |
August 4, 2007, 08:02 |
Re: Help on VOF boundary conditions
Try with open channel option
August 4, 2007, 19:20 |
Dear msureshkumar:
Thank you for your reply. But FLUENT 6.0 doesn't have open chanel option? Do you know any other way? Kelly |
August 7, 2007, 07:22 |
Hi kelly, For such a model you can use for both surfaces presure outlets. If the weir outlet is only partialy filled with water you can also try setting the top cover as a wall and weir outlet as a presure outlet. It should help with reversive flow at the cover that will probably apear if you will simutale it with the first option. rafal
August 7, 2007, 10:45 |
Thank you for your help, rafal. I tried as you said,however there are "reverse flow and turbulent viscosity limited to viscosity ratio***" warnings even if I extended the domain downstream. Do you have any suggestions to remove this? By the way it is a 2D problem and a broad-crested weir with the same width as channel.
I have one more question to ask about. In setting the initial values,how to determine Gauge pressure and water volume fraction? Are they mean values of the whole domain? Kelly |
August 7, 2007, 11:41 |
Hi Kelly.
I am not sure if your problem is a steady or unsteady. As I imagine the problem with computations is caused by the solver connected to not good definition of a problem and i think it will help to try first to define better initial conditions. It would be good to fill the domain with the water to the level of weir top . to do this you have to: 1: adapt a region of a quad shape region/adapt... 2: fill this region with water solve/initialize/patch... make sure also that operating presure location is where air phase is. At the outflow use the pressure of the operating conditions and before adapting region initialize with setting 'compute from...' and chose outflow. good luck, rafal. |
August 11, 2007, 12:29 |
Hi,rafal:
The problem is unsteady.I tried as you suggested:Adapt a region then patch with vof=1; Set the open air as pressure outlet BC. The result seems not right. Most of water run to the Open air domain boundary not to the outlet. Do you know what's the possible reason? Thanks a lot for your help! Kelly |
August 13, 2007, 05:37 |
Kelly, It is hard to say without seeing results but there os one possible reason. If the open air domain is above the water (and outlet) check your gravity settings. if the y axis is direcetd up, you should set negative gravity acceleration (wich is not default).
Rafal |
August 13, 2007, 10:16 |
Thanks for your great help, Rafal. You are right. I can't believe I made such an obvious mistake!
Kelly |
boundary conditions in FLUENT VOF for open channel flow | newcomer | Fluent Multiphase | 32 | May 4, 2020 07:28 |
Impinging Jet Boundary Conditions | Anindya | Main CFD Forum | 25 | February 27, 2016 12:58 |
CFX doesn't continue calculation... | mactech001 | CFX | 6 | November 15, 2009 21:25 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 6, 2008 23:17 |
VOF and setting boundary conditions | dave00001 | FLUENT | 0 | January 25, 2008 12:37 |
