August 5, 2007, 11:03 |
Running fluent parallel with PBS
I am trying to configure fluent to run on my new cluster with a TORQUE/PBS scheduler. I can run serial jobs but when i try to run parallel jobs I get mpid errors. Here is the PBS script I am using fluent 3d -g -pnmpi -t$NPROCS -cnf=$PBS_NODEFILE Here is the error I get Starting /opt/Fluent.Inc/fluent6.3.26/multiport/mpi/lnamd64/hp/bin/mpirun -TCP -f /tmp/fluent-appfile.6034 mpid: Cannot create shared memory segment of 1073766400 bytes Any help regarding this is very appreciated. Thanks Jaggu |
June 8, 2011, 11:29 |
try to use insted of -pnmpi , -mpi=hpmpi or -mpi=hp-mpi i am not sure between the two but one definitely works
Parallel Fluent Error in Batch Mode | Justin | FLUENT | 3 | November 28, 2016 10:50 |
parallel fluent runs being killed at partitioing | Ben Aga | FLUENT | 3 | June 8, 2012 10:40 |
running a journal file in Parallel FLUENT | novice | FLUENT | 0 | June 15, 2010 04:19 |
Parallel speedup Fluent Gigabit Ethernet Myrinet etc | tehache | OpenFOAM Installation | 5 | September 7, 2009 05:51 |
Parallel Fluent with Mandrake | Daniel Dotta | FLUENT | 1 | May 19, 2005 15:30 |
