'Tetrahedral meshing has failed for volume...' |
February 6, 2009, 16:14 |
My question is related with Gambit. I am doing some modifications on 3D truck model. One of this modification is adding side mirrors to truck. I created the side mirrors on truck geometry and meshed the all surfaces of side mirrors one by one. Then i wanted to create volume mesh on the geometry but it did not mesh the volume and it gave an error on the text screen of Gambit like this; "Tetrahedral meshing has failed for volume v_volume.57. This is usually caused by problems in the face meshes check the skewness of your face meshes and make sure the face mesh size are not too large in areas of small gaps." Before adding the side mirrors to truck geometry, there were no error on meshing the volume. So, i guessed that the error was related with side mirror geometry. But, although i check both faces and face meshes of side mirror geometry, there is no error message related with them. Furthermore, what can be the reason for not meshing the volume? What can i do to mesh the volume? Thanks, Murat |
February 9, 2009, 20:07 |
Re: 'Tetrahedral meshing has failed for volume...'
Try using size functions around the side mirror geometry. See if that would help.
February 10, 2009, 00:45 |
I tried size functions but this time Gambit gives error message like that: " TG_Mesh Domain failed with error code 1. A size function is already associated with the following entities, thus the required uniform mesh size is ignored during meshing"
I did not understand what this message mean. Before i did not try size funtion on geometry but the error message mentions like that. |
February 10, 2009, 03:49 |
Well, it is hard to troubleshoot your case without seeing the problem first hand.
I would recommend re-meshing your case from scratch. Do a 'Reset Mesh' in the command line, and mesh your edges, surfaces and volumes again. Ensure that your sizing are all similar to the previous case if you want to compare the two results together. Hope that helps. |
February 10, 2009, 06:36 |
you should have an small egde somewhere
February 19, 2011, 04:22 |
bing
Rep Power: 15 |
I had the same error. I discovered a vertex from one surface that was very close to another surface so that a 3D tet element was not able to be created during 3D meshing. The vertex closeness to a surface is shown in a rough diagram below.
|-----| |-----| | |_._| | |---------------| |
Tetrahedral vs. Hexahedral Meshing for CFD | Andy Bartels | Main CFD Forum | 16 | September 20, 2019 10:06 |
Failed in volume meshing | MANOJKUMAR | FLUENT | 0 | October 19, 2005 06:19 |
tetrahedral meshing in square channel | Aashutosh Magdum | FLUENT | 4 | May 28, 2005 20:27 |
Initialization failed for volume meshing?? | Ng | FLUENT | 1 | March 15, 2005 08:00 |
tetrahedral meshing Codes | Heinz Wilkening | Main CFD Forum | 1 | August 26, 1998 14:03 |
