August 8, 2007, 09:29 |
Urgent please!!!! Error messages in Fluent
Hi all, Thanx for ur time and attention. I have created a cas file by appending two cas files and also created the interface (coupled) between them. When I try to open the new cas file, it gives the following messages:
Error: access: unbound variable Error Object: get-var Error: CDR: invalid argument [1]: wrong type [not a pair] Error Object: #f I have checked the original two cas files and there seems to be nothing wrong with them. can somebody give suggestions to overcome this. Thanx in advance. Sharma. |
August 8, 2007, 14:56 |
Re: Urgent please!!!! Error messages in Fluent
append case file can give spurious results due to differences in the cases. I would merge the meshes via utility tmerge or use TGrid then use file/write-bc and read-bc to apply the boundary conditions from the cases.
August 9, 2007, 00:47 |
Thanx for your suggestion, will try and get back to you.
Display Modes | |
problem of running parallel Fluent on linux cluster | ivanbuz | FLUENT | 15 | September 23, 2017 20:12 |
few quesions on ANSYS ICEMCFD and FLUENT | Prakash.Paudel | ANSYS | 0 | August 12, 2010 13:07 |
Urgent Help Needed!!! (regarding FLUENT UDF) | dsen | FLUENT | 2 | May 28, 2010 14:36 |
Fluent connection with simulink by TCP/IP | Tanktruck | Fluent UDF and Scheme Programming | 1 | June 28, 2009 13:56 |
Urgent help needed- FLUENT to ANSYS | Omer | Main CFD Forum | 3 | September 18, 2006 11:24 |
