Home > Forums > FLUENT
hi joe. please read this
Old   August 9, 2007, 06:45
Default hi joe. please read this
majd
hi Joe, i saw in a archived forum following conversation:
My calculation is a coupled unsteady problem. After several periods, if the result is not meet the conditions of convergence,the calculation will be restarted from t=t0. Now , my question is ---
"How can I re-set the iterated time to the start time t0 in fluent UDF?"
reply:
Hi! you have to type in the TUI: (rpsetvar 'flow-time 0)
(NOTE: you have to type the parentheses too!) Now I try to do that using a UDF and let you know. Luca
what's your idea about it?
Old   August 9, 2007, 07:33
Default Re: hi joe. please read this
Joe
Running (rpsetvar 'flow-time 0) in the TUI will not magically revert the current stored values of velocity/pressure/ ... back to their initial values.
As far as I know you cannot revert a simulations results back to its initial guess without reloading the relevant case/dat files.
I am currently working on a problem that could really use the ability to regress one or two timesteps without going through the huge file IO penalty (particularly on clusters) of re-reading a previously saved cas/dat file. But this cant be done AFAIK ... Fluent only keeps what it needs to perform the next time step in memory.
Old   August 9, 2007, 09:01
majd
hi joe, thank you so much for your reply. i really don't want to revert a simulations results back to its initial guess. i want to change only my current simulation time without any changig on the other variables. i want to reiterate a time step with the new data that FLUENT obtains through its current calculations.
Old   August 10, 2007, 06:16
majd
can anyone answer my question?
Thanks in advance.
Thread Tools
Trackbacks are On
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
Data Read Error ansys CFX fcabrales CFX 3 April 18, 2011 18:21
How to read vtk format using fortran code? xiyuqiu Main CFD Forum 2 December 11, 2010 21:18
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 15:37
how to read a gridpro 2d file into starcd shell prc CD-adapco 3 December 21, 2006 19:59
