August 14, 2007, 06:00 |
Error: Segmentation Violation
Hello
I am facing problem with macro C_WALL_DISTANCE(c,t). While writing a UDF for modifying the turbulent viscosity, I encountered the problem of segmentation violation, everytime I use C_WALL_DIST(c,t). However, the same UDF works well with enhanced wall treatment seting in the Viscous model panel. I need to generalize my model so I am still to find a solution of the same. Would be really grateful if someone could give piece of advice. Regards Srikant. |
August 14, 2007, 10:55 |
Re: Error: Segmentation Violation
I found the solution
use /solve/set/expert option before using above macro. Sri. |
Segmentation violation | louiza | FLUENT | 16 | June 27, 2017 15:41 |
Segmentation Violation | Corentin | FLUENT | 1 | February 13, 2011 01:07 |
Defining Multiphase by text and by gui = different result and Segmentation Violation | RPJones | FLUENT | 0 | June 9, 2009 16:24 |
segmentation violation | wasan | FLUENT | 0 | December 23, 2008 11:37 |
Access violation - Help please | AlwaysLearning | FLUENT | 3 | August 22, 2006 12:21 |
