August 13, 2007, 14:13 |
set surface monitor as residual
I'm running fluent as a batch file in the background. It seems it will either do all the iterations I specify, or it will end if the residuals converge. My residuals decrease quickly, but depending on my initial guess sometimes the temperature characteristics are still changing. Therefore is there a way I can look at the residual from a surface monitor to determine when the iterations end? How would I do this? How would I set the surface monitor to look at the residaul of itself?
thanks |
August 14, 2007, 02:38 |
Re: set surface monitor as residual
solve>monitor >surface
August 14, 2007, 09:21 |
I understand this is the way to set a surface monitor, but under the options of what to monitor I don't see "temp residual".
And I want to set it as a residual so then in my batch run, the run would stop when all the residuals are under a certain value, so essentially I could stop the iterations once my temperature stops changing. Do you know how to do this? thanks |
August 14, 2007, 09:35 |
i dont know as well, I use it and stop it manually sorry
transsonic nozzle with rhoSimpleFoam | Unseen | OpenFOAM Running, Solving & CFD | 8 | July 1, 2022 06:54 |
problem with Min/max rho | tH3f0rC3 | OpenFOAM | 8 | July 31, 2019 09:48 |
Multiple floating objects | CKH | OpenFOAM Running, Solving & CFD | 14 | February 20, 2019 09:08 |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 16 | March 4, 2017 08:30 |
MRFSimpleFoam amp cyclic patches | david | OpenFOAM Running, Solving & CFD | 36 | October 21, 2008 21:55 |
