-   -   files .msh of fluent (http://www.cfd-online.com/Forums/fluent/45736-files-msh-fluent.html)
DDOU August 15, 2007 18:20
I don't have the following files in my directory of fluent.
evaporate_liquid.zip sector.msh airfoil.msh tubebank.msh film_hex.msh film_tet.msh filmcool.msh elbow.msh rocket.msh Jmprof.c gascomb.msh cvd.msh Inlet.c hydro.msh disk.msh bmower.msh fan.msh fanstage.msh dtator.msh rotor.msh sliding.msh lfuel.msh
I exorte you to help me by sending me this files.
thanks in advance
A CFD User November 25, 2010 12:23
Hi there,
Did anyone send you the files you requested? I need them too. If you have them now, could you let me have them too?
Thank you in advance
teguhtf December 3, 2010 20:25
Hyy Guys,,
Check this out http://www.liv.ac.uk/~em22/CFD/data/
hope it helps
teguhtf
A CFD User December 4, 2010 06:02
Originally Posted by teguhtf (Post 285937)
Hyy Guys,,
hope it helps
teguhtf
Thank you very much. Although I have already decided to work on another tutorial, this link contains the .msh files I needed.
teguhtf December 6, 2010 23:09
You're welcome..
By the way, my tutorial file (pdf or html) has gone. could you tell me the link of its tutorial?? thank you..:)
teguhtf
A CFD User December 7, 2010 05:26
FLUENT 6.3 Tutorial Guide
Originally Posted by teguhtf (Post 286280)
You're welcome..
teguhtf
I'm not sure which tutorial exactly you are trying to find. But, here are the links to the ones I decided to work on:
http://my.fit.edu/itresources/manual...help/tutfiles/
http://my.fit.edu/itresources/manual...pdf/tg/pdf.htm
The first one contains Fluent 6.3 Tutorial Guide PDF file, and the second, tutorial mesh and solution files.
hope it helps
Good luck
Basy January 30, 2011 01:19
Hyy Guys,,
hope it helps
teguhtf
dear teguhtf
thankssss, your link helped me alot
ilperalta April 21, 2011 09:32
mprof.c file nozzle flow for a solid propellant rocket
i can't find mprof.c file (nozzle flow for a solid propellant rocket)
can someone help me????
student88 November 22, 2011 22:00
I urgently require the following files from the Fluent 6.1 folder:
driver40kw.msh
driverbc.c
Please, kindly upload them.
These files are regarding the FLUENT tutorial Steady, Incompressible, Turbulent Flow Over A Backward-facing Step
These files aren't located in the documentation folder of FLUENT 6.3
and I can't manage to find them online.
student88 November 22, 2011 23:31
These two files should be included in "Introduction.zip", located in he Fluent 6.1 "tutfiles" documentation folder
elham.sly67 December 16, 2011 08:19
I don't have the following file of cvd msh in tutorial 13
please help me
ngoctm January 31, 2012 02:32
Hi, ilperalta
You can search phases are "UDF mprof.c" in Google Search, then click into 2nd link.
Good luck.
PS: I can send that file for you if you want.
Regards,
rohanuict September 25, 2012 15:33
Can someone please send me the tutorial file sector.msh? I cannot find it.
my email: rohanuict@gmail.com.
Thank you.
