UDS Boundary conditions
Old   August 16, 2007, 03:59
Default UDS Boundary conditions
Max Perrotta
Hi! My problem is to set UDS boundary conditions, which depend on the results of iterations in a steady problem, on a planar interface between a fluid and a solid region. My UDS is vapor mass fraction in humid air flowing on the solid wall. The problem is to impose the saturation value of mass fraction corresponding to the wall temperature at any single point (the saturation in ensured everywhere on the wall surface). So I need to update my UDS boundary conditions after each iteration of energy equation solution, that gives me the updated values of temperature. I tried to use a DEFINE_ADJUST macro but it doesn't work. It seems to me that the values computed by the macro at each iteration are overwritten by the boundary conditions that I initially set on the surface using the GUI "Boundary conditions" panel. How can I solve this problem? Every suggestion is appreciated.
Regards
Max
Impinging Jet Boundary Conditions Anindya Main CFD Forum 25 February 27, 2016 12:58
symmetry boundary conditions in cfx lost.identity CFX 41 May 22, 2013 07:21
OpenFOAM Variable Velocity Boundary Conditions NickolasPl OpenFOAM Programming & Development 2 May 19, 2011 05:37
[Netgen] boundary conditions and mesh exporting vaina74 OpenFOAM Meshing & Mesh Conversion 2 May 27, 2010 09:38
