Home > Forums > FLUENT
When heat transfer coefficient is negative?
Old   August 16, 2007, 04:38
Default When heat transfer coefficient is negative?
eve
hello
I simmulation about double-flow solar air heater.And when i check HTC.It's negative.It was wrong or not?And if it wrong the solution is?
Thank.
Old   August 16, 2007, 08:12
Default Re: When heat transfer coefficient is negative?
carno
HTC can not be negative. If the value is coming to be negative, means you have entered the temperature difference a negative value. Check the delta T
Thread Tools
Trackbacks are On
BOILING HEAT TRANSFER COEFFICIENT John CFX 3 April 4, 2012 17:50
calculate heat transfer coefficient in repeated geometry mullenc525 CFX 2 December 21, 2010 14:57
Distribution of surface heat transfer coefficient along the axial direcion of a tube andred FLUENT 0 November 16, 2010 22:13
Flow around pipes - heat transfer coefficient on the wall of pipe doodek Main CFD Forum 2 November 23, 2009 09:48
No results for solid domain Gary Holland CFX 10 March 13, 2009 04:30
