FLUENT - Fieldview
Hello Is it possible to open .dat file from Fluent 6.2 in Fieldview v10? Or the only way is to export data from fluent in Fieldview unstructered format? It would be great if someone could reply
Re: FLUENT - Fieldview
i have only experience of using the export function...
however, if you have a lot of files to export in fieldview format, then id recommend creating a journal file of commands to do the work for you. |
ok, i can do it also by execute commands. but the point is that i do not know how to import several files exported from fluent. this is needed to make time step simulation. maybe you know how to do it? in fieldview i am inporting data by unstructured format. other formats don't work. any ideas?
