Surface roughness in laminar flow
Old   August 16, 2007, 01:24
Default Surface roughness in laminar flow
carno
I am not solving a laminar flow problem. In that do surface roughness value matters? Since I am under predicting the pressure loss value in a system?
Where to input the surface roughness, I am not finding any place in wall BC.
Thanks
Old   August 16, 2007, 02:45
Default Re: Surface roughness in laminar flow
chouaib
In the Wall boundary conditions Panel.
Old   August 16, 2007, 04:05
Dr. Flow Squad
Surface roughness have NO influence on pressure drop at all in laminar flow. It is only Reynolds dependent: dP = rho * 64/Re * L/D * ½*V^2 -Dr. Flow Squad http://tinyurl.com/2gkjh8
Old   August 19, 2007, 14:35
AAA
Hi
You can specify roughness height and roughness constant in the walls BC panel
Old   August 19, 2007, 15:52
chouaib
Hi AAA, You can see the message of Dr. Flow Squad. The flow is laminar. Chouaib
nutRoughWallFunction and Surface Roughness Documented AlanR OpenFOAM Programming & Development 64 January 6, 2024 07:13
Surface roughness in Flow-3d Marco FLOW-3D 3 June 3, 2018 02:15
Surface roughness alefem FLOW-3D 6 June 3, 2010 12:49
Problem with capturing water-spreading for free surface flow devesh.baghel OpenFOAM 2 December 10, 2009 01:21
Laminar Flow rvallejo CFX 1 November 16, 2009 09:49
