Home > Forums > FLUENT
Natural Turbulence Insensity
Old   August 20, 2007, 21:09
Default Natural Turbulence Insensity
Just a quick question. Does anybody know of a typical turbulence intensity on the inlet of an external flow domain? I am modeling vehicle aerodynamics and I want to specify a more realistic boundary condition. Does anybody know of a reliable reference for natural turbulence intensities on roads etc?
Best regards,
Old   August 21, 2007, 02:55
Default Re: Natural Turbulence Insensity
Hi Carlos,
The way I see it, you have two major possible situations:
- laminar, undisturbed flow in front of a car running at sufficient distance from other cars (hundreds of meters), when the level of turbulence intensity at inlet should be set, let's say to about 0.5-1%, and a turbulent viscosity ratio of 1;
- turbulent flow in front of a car running in the wake of another, in which case, if you really want a very realistic model, you should use an interpolated profile for velocity and turbulent quantities obtained from another simulation (taken at a proper distance), or if the car is running in highway-like conditions, with cars in front and behind, at approx. equal distances, you could use a translationally periodic condition for the inlet-outlet pair.
All the best,
Old   August 23, 2007, 11:12
Hi Razvan,
Many thanks for your suggestions. At present I am only interested in laminar flow in front of my vehicle. I just feel that having no turbulence intensity there is too clinical and unreal. Obviously there is an atmospheric boundary layer and low levels of turbulence in the air on roads.
I will try your suggestion of 0.5-1%. I doubt it will change much of the solution but I am writing a paper and want to do it by the book. I cannot find much in the literature on natural turbulence intensity levels but if you know of one for your suggestion please let me know!
Best wishes,
Thread Tools
Trackbacks are On
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 14:18
Natural convection with k-e turbulence model hello FLUENT 2 May 23, 2014 11:53
HELP!!! Natural convection with turbulence leotsien Main CFD Forum 0 October 29, 2010 03:23
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
