August 13, 2007, 04:28 |
viscosity limited
Hi i face whit 2meessages"turbulent viscosity limited to .." and reveres floe at ...on out flow" during solving a turbulant problem. i modeled 2 channel that cross eachother. i increase pressure under relaxation factor to 0.5 but i have convergnce problem whit qauntinuty equation. please help me. Whit king regards Rick
August 13, 2007, 05:40 |
Re: viscosity limited
There are 3 reasons for this message: first the mesh quality is poor(skewness etc), second improper use of turbulent boundary conditions and the third one is the poor initial values for turbulent quantities, check for these things.
August 15, 2007, 05:14 |
Dear Farhan my grid dosnt havy any problem . and what do you meam about use of turbulent boundary conditions? tankx alot Rick
August 16, 2007, 00:37 |
It is turbulent intensity and length scale at the inlet boundary
August 22, 2007, 06:23 |
yes, I think you have got the answer from Andrew
Display Modes | |
reversed flow at pressure inlet and turbulent viscosity is limited.... | cfdiscool | FLUENT | 10 | June 10, 2015 07:15 |
Turbulent viscosity limited to viscosity... | Cyril | FLUENT | 16 | October 4, 2007 07:12 |
Turbulence viscosity limited | Madhukar Rapaka | FLUENT | 0 | June 26, 2006 04:17 |
Turbulent viscosity limited to viscosity ratio... | Cyril | FLUENT | 8 | February 7, 2006 21:34 |
Problem of Turbulent Viscosity Ratio Limited | David Yang | FLUENT | 3 | June 3, 2002 07:13 |
