udf compiling problem
Old   August 20, 2007, 21:22
Default udf compiling problem
akr
Hi everyone. I have got a probrem on compiling udf. I have downloaded "Microsoft Visual C++ Express Edition" on C drive of my PC. Fluet is also on C drive. Now I can compile my udf which is on C drive. But I cannot compile udf which is on other drive. The problem is that my case and data file are not on C drive because of sufficient size of C drive. So I want to have my case and data files and use udf on other drive. Is there any way to do that? Regards,
akr
Old   August 21, 2007, 13:37
Default Re: udf compiling problem
AAA
Hi
The case, data and udf files must all be in the same directory. Why not move the udf to the directory where the case and data are?
Old   August 21, 2007, 21:05
akr
Hello
Thank you for your reply. Now I can compile my udf. I just went to the directory where the case, data and udf files by using command prompt of Visual C++. Then, compiling was done.
Thanks.
akr
Old   August 22, 2007, 07:14
AAA
My pleasure!
About UDF compiling issues: 'nmake' Haoyin Shan Fluent UDF and Scheme Programming 15 November 4, 2019 18:05
A problem about 'printf' and 'Message' in UDF. LICH Fluent UDF and Scheme Programming 2 May 2, 2013 02:45
what's the problem with my udf zzyan FLUENT 0 November 4, 2010 03:56
HELP! Problem compiling UDF function Syrakus FLUENT 6 April 7, 2006 10:48
UDF compiling problem for 3D simulation Marijo FLUENT 1 March 28, 2006 03:21
