Fluent/Gambit and vista
Does it matter which version of vista you have? I always had xp pro. Will fluent/gambit exeed work on vista home basic/home premium/business/ultimate? which ones many thanks
Re: Fluent/Gambit and vista
I've tried Fluent/Gambit on Vista Business edition... works fine. cheers
which is the version of Exceed that you uses? I have 2007's version but it does not working in vista.
which version of vista?
I have windows vista ultimate edition.
well Tomasz says it works...i think ultimate and business are similar (different from home) but correct me if im wrong. So it may depend on fluent version....neither fluent nor gambit work????
Problem only Exceed, then cause Gambit mal-function.
Good News !!!!
The problem of Exceed is just a Vista security. There is a small picture if shield in ICON. Just change the security of that file. Then, Exceed can run properly. : ) : ) : ) |
Can you please elaborate? Do you mean Exceed 2007 works in Vista?
Which version are you using? Is it exceed 2006 or exceed 2007?
please tellme how to change the security of that file,thanks
gambit working in vista home edition
well, bro, i had the same problem, there is what i did.. just in the gambit icon, click the option that allow execute the program (gambit) as administrator.. after you did click on that... a dialog box will appear and then, just say it yes (the dialog box is about a warning for a possible security problem, but gambit is not a threath...)
then, the program will work .. good luck and sorry for my english... by the way, im using vista home premium edition, and i refered to click the gambit icon but with the left button of the mouse ... |
Thanks!
Dear Alejandro thanks indeed for you simple and very useful help.
Actually i was going to change may vista to xp but however your help worked for me a lot and i dont have to change it now. My gambit works properly with vista |
hello Sahoora
about FLUENT and Gambit.. i m studyng a PhD in the Instituto Politécnico Nacional in mexico city... maybe we can share knowledge about this programs.. my email addres is alejandro_1980@hotmail.com .. can i have yours?? you can send me a email ... greetings..;) |
Better X server under Windows
I use Xmanager 4 under windows 7 64 for Gambit.
It has better performance and eliminates some of the quirks of Exceed. You have to use this command if you don't use Exceed: C:\Fluent.Inc\ntbin\ntx86\gambit.exe -r2.4.6 -dev X11 |
