Error Display of FLUENT on LINUX FEDORA 7
I have been working with FLUENT on LINUX FEDORA 7, simulation of my problem: that's OK, But when go to Display->Contours->Temperature, Error: Cannot find Display! Plot->XY->Pressure, Error: Cannot find Display! Can somepody help me? please! Thanks! |
Re: Error Display of FLUENT on LINUX FEDORA 7
Hi
Are you choosing specifying a proper surface to display the results on? One more thing. Is your scale right? Check if you are using the same scale (dimensions) in the simulations and the output. |
No, I don't use proper surface
yes, I'm using the same scale in the simulation and the output thank's |
Are you sure that the DISPLAY environment variable is correctly set?
how to do this? I think that no!
please help me! |
It's been some time since I last used Unix extensively, so I can only give some hints.
At a command prompt (shell prompt) type: echo $DISPLAY Assuming your computer is called "mypc" your system should return something like: mypc:0 or mypc:0.0 The DISPLAY variable is the place where the Fluent process looks if it wants to determine on which computer to look for a process to contact to have it's output displayed on screen. Hope this helps. |
Try this in a Terminal
fluent 2ddp -driver x11 then load your case and data and you should be able to display your data. |
Thanks a lot! This way worked perfectly!
Thank you! |
