August 30, 2007, 15:16 |
urgent need for help
Hi all I have to model the flow and heat transfer in triangular channel .My problem is I dont able to mesh this channel when I mesh the adges and the faces the work is goen good but when I mesh the volume the fluent display an error message . Please can any one help me by guiding me to how to mesh the volumes with best regards and thanks
August 30, 2007, 17:17 |
Re: urgent need for help
do you have any bad elemeny? i mean with bad skew angle or something like this?
Meshing the faces, what kind of mesh are you using? have you tried a Map or Submap mesh? If you made a Pave mesh, try these ones. Good Luck! |
August 31, 2007, 01:20 |
I tried all type of mesh but the problem is the same the faces is meshed but the volume did not meshed .and the fluent disply error message about skewness .Not that my work is one microchannel i.e the dimension is very small in micron is that matter affect on the meshing thank you
August 31, 2007, 04:56 |
umm...meshing is hard stuff i believe u may choose wrong type meshing in face and volume correct me if i wrong
Urgent - Polyflow - particle tracking visualization -Urgent | shafaatht | ANSYS | 0 | October 13, 2010 04:56 |
Urgent, Urgent, a UDF problem, PLEASE HELP!!! | Max | FLUENT | 1 | September 24, 2010 20:30 |
Urgent...urgent...plss!!! | astronome | FLUENT | 0 | October 16, 2009 07:17 |
tmerge urgent urgent | jessica | FLUENT | 4 | July 15, 2006 13:37 |
very urgent pleasade:Cl and Cd values for airfoil | Liaquat | FLUENT | 2 | April 27, 2006 12:20 |
