Home > Forums > FLUENT
Please Help with UDF
Old   September 4, 2007, 09:39
Default Please Help with UDF
rosol
Hi
I have to write UDF to specify the fluid properties as a function of temperature therfore I have four codes (UDF) for viscosity ,density,thermal conductivity ,and Cp but when I interpret these UDF in fluent the fluent save only the last one and it only appear in the drop down list.My question is how can I interpret and save more than one UDF in fluent in the same time .
I will be happy for any help Thank you
Old   September 4, 2007, 11:15
Default Re: Please Help with UDF
treit
You should compile your UDF's, but if you want to interpret you can keep all of your DEFINE macros (4 in your case) in the same source file with the include udf.h preprocessor directive.
p.s. I thought that the termal conductivity could not be altered by a UDF in Fluent.
Old   September 4, 2007, 11:37
Giacomo
Hi. You can keeping interpreting your UDF. You have to do like this:
DEFINE_xxx(xxxxxxx, .., ..) { write your first udf } in the same file you attach all the other udf's just placing them one after the other:
DEFINE_yyy(yyyyyy, .., ..) { write your first udf } DEFINE_zzz(zzzzzz, .., ..) { write your first udf }
At the end, when you interpret, you will find xxxxxxx yyyyyy zzzzzz in you drop down menus. Enjoy!
Giacomo
Old   September 4, 2007, 11:39
Giacomo
DEFINE_yyy(yyyyyy, .., ..) { write your second udf }
DEFINE_zzz(zzzzzz, .., ..) { write your third udf }
xxxxxxx
yyyyyy
zzzzzz
Giacomo
Old   September 8, 2007, 07:41
ali
i remeber that you can not write a udf for thermal conductivity, it requires additional solver capabilities.please research this
Thread Tools
Trackbacks are On
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
Dynamic Mesh UDF Qureshi FLUENT 1 December 2, 2009 01:27
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 05:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
