Home > Forums > FLUENT
Coal combustion- Moisture %
Old   September 5, 2007, 13:03
Default Coal combustion- Moisture %
Michael
Hello I'm currently trying to do coal combustion. I read the manual/tutorials about how to input coal properties. All of these shows you how to input fuel assumming certain % volatiles, % char, % ash. What if your proximate analysis contains moisture level. How would you input the coal's percentage of moisture in fluent
Thank you in advance
Old   September 7, 2007, 18:15
Default Re: Coal combustion- Moisture %
Allan Walsh
Have you tried the "wet combustion" panel in the injection set-up?
Old   September 10, 2007, 04:39
IgorB
Hi!
I'm having similar problem here. I'm trying to simulate biomass combustion with high moisture content using two mixture fraction (volatiles and char). The question is should I include liquid water H2O(l) in the same stream with char? Fuel stream (volatiles) are given empiricaly so water cannot be added there. "Wet combustion" tab is greyed for some reason.
Old   September 10, 2007, 13:49
Allan Walsh
Igor - check out some of the previous discussion on biomass combustion.
Old   September 11, 2007, 03:56
IgorB
I did that but I could not find the reason why "wet combustion" tab is greyed in Fluent (is it maybe usable only for species transport model?). I tried to include moisture by adding H2O(vapor) in char steam and correcting latent heat in materials panel but i'm not sure if it is correct way. I don't exactly know what laws are included for volatile stream and char stream respectively when using two mixture fraction. I would appriciate any help i can get. Thanks in advance, Igor B.
Thread Tools
Trackbacks are On
Problem on EDC model for coal combustion lei FLUENT 4 September 3, 2015 09:39
Turbulent Dispersion for Coal Combustion gravis CFX 2 March 24, 2010 00:56
Coal combustion and ash reaction kinetics sega Fluent UDF and Scheme Programming 0 January 21, 2010 09:05
moisture in coal combustion Sheng FLUENT 3 June 15, 2003 19:43
Coal combustion with Fluent 4.5 or 5.0! Sriram Popuri Main CFD Forum 2 July 24, 1999 11:34
