-   -   udf u1064 nmake (http://www.cfd-online.com/Forums/fluent/45942-udf-u1064-nmake.html)
ali September 6, 2007 04:03
udf u1064 nmake
hi all, i am trying to compile a udf using nmake command.i am doing each step given in fluent tutorial,but i got a error message as follow;
D:\>cd libudf\ntx86\3d
D:\libudf\ntx86\3d>nmake
Microsoft (R) Program Maintenance Utility Version 8.00.50727.42 Copyright (C) Microsoft Corporation. All rights reserved.
NMAKE : fatal error U1064: MAKEFILE not found and no target specified Stop
this is the first time that i used a udf and i can not overcome this problem.is there any other way to compile this udf or what can i do to solve to problem.
i would really appreciate if you could help me
Joe September 6, 2007 05:38
Re: udf u1064 nmake
Try to compile a simple hello world type c program from a command line to verify that your compiler is correctly configured.
ali September 6, 2007 06:15
Re: udf u1064 nmake
thank you a lot Joe;
in this case error mesage is changed to;
NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio 8\VC\BIN\cl.EXE"' : return code '0x2' Stop.
asaleghahreman October 15, 2010 11:32
Originally Posted by Joe
;145139
I have the same error as Ali said.I dont understand how to solve this problem.I would really appreciate you if u could help me.
